| Message |
After 19 years and 157,000 miles the rubber boot was shot and i had excessive play in the ball joint assembly
 the ball joint assembly must be pressed out, it took a few hours to assemble all parts and develop this technique for the first side, the second side only took around 45 min. Required tools Basic hand tools, wrenches, socket set Heat gun tie rod end separator short piece 1 1/4 inch diameter black pipe with end cap
 tie rod press- available for rent at auto parts stores
 First, remove the cotter pin, and nut, from assembly and remove tie rod with remover
 remove locking bolt
 The following set-up is used to press out the ball joint as the commercial press will not fit in the space available.
 note the required nuts on the forward aspect of the assembly
 now apply heat, i chose a heat gun as the surrounding metal is aluminum
 making progress
 success
 New ball joint assembly with part number
 Next apply a little silicone spray and use the tie rod press and an impact wrench to press the new ball joint into place
 Replace locking bolt, nut, and cotter pin
 Good luck!
